s.gilletly
- FFLE1011MW2
- Frigidaire
- 6-10 years
Hello All,
I’m new to the thread. I have a Frigidaire stacked washer dryer. Model FFLE1011MW2. The washer stays stuck in agitation mode when the pump turns on to drain. The pump works, the washer runs through its cycle but when it gets to the final spin it, it stays agitating and not spinning resulting in wet clothes and a small amount of standing water you can hear in the bottom of the drum if you manually spin the drum back and forth with your hand.
I was thinking maybe if the machine can be reset to factory default that may work? Ive checked the pump and it works. I’ve checked the drive belt and it’s good. It feels like an electrical issues or the timer is not working correctly and triggering that final spin out. Any help would be appreciated
