FFLE3911QW Washer will not cycle
jeff_wgood
Indiana
FFLE3911QW
Frigidaire
Hello, my stackable washer/dryer is giving me some issues. It first started out that it wouldn't drain. I reset the breaker and now when I select a cycle it goes into the initial drain but then it faults out. I've tried to get into the diagnostics and am unable to do so. It does beep when turning the knob through the cycles but none of them work. The lid locks when it tries to go into a cycle and unlocks when it faults out. The dryer works perfectly fine without any issues. Any help would be greatly appreciated. Thank you
Hi Jeff,
I've been reading some other posts on this problem, you have 2 control boards, other members have found one of the control boards had burnt spots on them, and another found the connector pins in them have been coming out on the control board itself.
So check both your control boards first.
This is the main control board for your model:
5304511966 Control-Electrical
This is the motor control board for your model:
808653801 Board
jeff_wgood
Indiana
Thank you Jake, my instinct was telling me it was the main control board and have already ordered it. When I get home ill pull the old one out and inspect it for any burn marks and loose pins.
Ok Jeff, sounds good.
