FFMV1645TS Frigidaire Microwave - Doing the 3-seconds then stop thing, also now a touchpad issue
dh166
dallas
FFMV1645TS
Frigidaire
So, we had a storm the other night including some power surges. Outages were no more than a few seconds, and no breakers in the panel tripped. However, next day the microwave would start with light and fan but no magnetron (as far as I could hear) and then shut itself off after precisely three seconds. I googled and was directed to door switches, which I checked for continuity. All three were good, as was the fuse. I disconnected the unit to make these checks.
This evening, I read a post that suggested the processor could be 'confused' after the outage and to try a re-start. That being a simpler fix to try than anything else, I plugged it back in. The panel came up blinking 12:00. I hit the 30 sec cook button and nothing happened.
Thinking I might have to set the clock before it would begin operations, I pressed the clock setting button and then began pressing numbers for the time. It accepted the first number but nothing after that was responsive, not numbers or settings buttons.
Prior to unplugging the unit and checking switches, all of the panel functions worked. Any thoughts on what the initial problem might have been, what's causing the new problem, and what I might have screwed up while I had the panel off?
