FFRE1233U1 Frigidaire window AC unit plug replacement
Kathy0619
Louisiana
FFRE1233U1
Frigidaire
I need to replace the AC plug . When I took the old one off I did not mark wher each wire went. I know the green is the ground and where it goes but not the other two. Can someone help? I think the pictures show my two options.
Many units have a small wire diagram inside. Could be glued inside the cabinet, on a foam cover, rolled up with the controls.
FFRE1233U1
I keep finding FFRE1233U10 & FFRE1233U1E0
Is this unit 120 volts AC?
If yes, my *guess* is black to the relay in first pic and neutral to the open terminal in pic two.
jeff sr.
If you get a chance, keep us posted.
jeff sr.
