FIXED FFSE5115PW0 Frigidaire Dryer E61 error code
Mcnabb75
Greenville SC
FFSE5115PW0
Frigidaire
Dryer model is FFSE5115PW0
Has an E61 code which is a heat relay. The dryer will run for 5 minutes and then turn off. The customer ordered user interface board and main control board, per the instructions of tech support. Neither resolved the issue.
I put it on air dry and it ran for a couple of minutes, shut off, and than e64 showed up. Not sure why with the heat not running.
Is this a burner element issue?
E64=Heater Open Circuit --->Heating element or wiring defective
Unplug the dryer, then open the dryer to get access to the heating element, then ohm test it, there is a video in the heating element part link that shows how to ohm test it.
Here's the heating element for your model you can order if needed:
Heating Element Assembly 134792700
Excellent Jon, glad to hear the new heating element fixed it.:)
