FFSG5115PW0 Frigidaire Dryer DOOR OPEN STILL
Michael Inzirillo
NY
FFSG5115PW0
Frigidaire
Hello
I have changed the following parts on my dryer.
Door Latch
Door Switch
Circuit Board
I still have the DOOR OPEN error. Can anyone please help?
Thank you
Mike
Will the code shut off if you manually push the door switch? Wiring been checked to and from the door switch? Wire might have been cut or has a loose connection.
Michael Inzirillo
NY
I pushed the door switch close manually. I changed the bulb also and that dosent light either. I took the harness that comes from the machine and did i bypass connection and still nothing. is there another part that could be bad?
DOOR OPEN error
These happen at the same time?
Has both thermal limiters been checked?
Has the neutral/white wire been checked? ( that could effect both at the same time )
