johne78
- FFSG5115PW0
- Frigidaire
- 6-10 years
model# FFSG5115PW0
dryer wont dry
This all started as the door open code, I had this once before, i opened the machine and started checking the thermal fuses, ended up replacing them all (all were open)
Then that got rid of the code, however, now the heat never kicks on.
I have replaced both the front control panel and the control board, (bought 2 control boards now) still no heat.
I then replaced the motor switch with no luck.
I probed around a bit and have found that I have voltage to the heater relay, but no voltage on the other side of the relay going to the ignitor and coils, when jump that connection with a wire the ignitor lights up.
any ideas?
dryer wont dry
any ideas?
