FIXED FFSS2622NW0 Frigidaire Refrigerator is not making ice and have to wait a long time for water
robrpb
Florida
FFSS2622NW0
Frigidaire
My friend's refrigerator takes a long time to dispense water, having to hold the glass for several minutes before it starts to fill the glass. When it starts to fill the glass the flow rate is good.
Also, the ice maker doesn't work. It will make a tray of ice cubes every 3 or so weeks and they are small. He has changed the water filter a couple of times with OEM filters and it didn't fix either problem. Thanks for your help.
Rob
Hi Rob,
The filter housing has an inlet and an outlet. Disconnect the outlet line on the filter housing and check the pressure. If the pressure is good make sure the water reservoir isn't frozen. It sounds like either the filter housing or the water reservoir is the problem.
(click to enlarge)
Here's the filter housing:
Water Filter Housing 242009602
robrpb
Florida
Thanks Jake for your reply. I will pass your info on to my friend. I have a Samsung refrigerator and I don't have a filter installed in the refrigerator, because I run my water through a R/O system and then to the refrigerator. Can my friend's Frigidaire work without a filter in a similar way? Thanks.
Rob
Yes Rob, just bypass the water filter with a John-Guest Union connector, I believe it's 5/16".
robrpb
Florida
Thanks Jake. It's good to know for the future. Now we have to fix the current problem.
Rob
Also Rob, make sure your friend has good strong water pressure coming to the refrigerator from his water supply line.
What I do is pull the refrigerator out from the wall, then turn the water supply line off, then get a bucket or container to catch water in and put the water supply line in the bucket and turn the water supply line back on, to double check the water pressure is good.
robrpb
Florida
Thanks Jake for the additional information.
Just curious for my own understanding of the problem, how come you eliminated the water valve as a possible problem?
Rob
I didn't, I said this above:
But I should of said if the water pressure is low, check the water supply pressure TO the water inlet valve FIRST, if that is good, then yes it would be the water inlet valve.
Here's the water inlet valve for your friends model:
242252702 Water Valve
Also check the INLET TUBE LINE to the water filter for good water pressure.
robrpb
Florida
Thanks again Jake for your reply. The main reason I asked about the water inlet valve was to help me to troubleshoot future problems and to understand how the system works. I read about the water inlet valve in other posts, but their problems were a little different and I don't know how the ice and water are related.
Rob
robrpb
Florida
Jake, I just saw your last post. I missed it when I was reponding to your previous post. I appreicate your help and the things to help troublshoot the problem. Thanks.
Rob
Ok Rob, sounds good.:)
robrpb
Florida
Jake, we replaced the water inlet valve on Saturday and it fixed the problem. Thanks for all your help.
Rob
Excellent Rob, glad to hear the new water inlet valve fixed it.(y)
