FGB24L2ASC Frigidaire oven wont heat up anymore after using the broiler
Dragonflames
Utah
FGB24L2ASC
Frigidaire
i have a frigidaire gas wall oven and it had been working fine since we bough it, but 2 days ago we used the broiler for the first time on it and that worked just fine. But since then we have tried to turn it on and it does not work, when you push the buttons and hit they click like they normally would to turn it on but it doesnt sound like anything else is happening no gas comes through.
Does BAKE still work?
When you put it on BROIL, open the oven door and see if your glow bar igniter comes on, you will see a orange glow from the bottom of the oven.
If BAKE works fine still, but BROIL does not, then the problem is the control board, because BAKE and BROIL on your model use the exact same glow bar igniter.
Here's the clock control board for your model:
318185350 Clock/timer
