- FGHB2844LF5
My Frigidaire refridgerator has had a number of problems (mostly related to the ice maker) in the two years that we have owned our house, but the freezer temperature has been very stable until recently. Over the past few days, the freezer has been fluctuating in temperature and I’m wondering if there are any suggestions on what to troubleshoot. It is set to 0 deg, but it went up to 11 degrees yesterday and stayed at 11 degrees overnight. When I returned from work, the freezer was at 9 degrees and an hour later it was back down to 0. An hour after that, it’s now at 11 degrees again. And yes, the freezer door is fully closed and making a good seal.
I’ve previously replaced the control board about 3 months ago, and cleaned out the freezer drain line when that got clogged about 2 months ago.
Any ideas what could be causing the temperature swing? Thanks in advance.
