FGHB2844LF7 Frigidaire refrigerator freezer not cooling
Ymartinez1
Houston TX
FGHB2844LF7
Frigidaire
I had a power outage, Frigidaire refrigerator and freezer not cooling. It's been on for over 24 hours and temperature still the same, not cooling.
Corrected Brand to Frigidaire
That's a Frigidaire model number. Be sure to read it off the model tag. Is the compressor running?
OK. if the compressor and condensor fan are working check the freezer evaporator fan and make sure it's working. If the evaporator fan is working, leave the machine plugged in and running and remove the evaporator cover and check the frost pattern on the coils. You want to see a very very light coat of white frost on all the coils top to bottom and side to side, no ice or snow.
