FGHC2331PF (French door) Refrigerator - ice maker only makes ice when I manually reset it
jbottomley7
Charleston, SC USA
FGHC2331PF
Frigidaire
We are currently renting and the ice maker on the Frigidaire Gallery (FGHC2331PF) doesn’t produce ice. It WILL produce very small ice and only after I manually reset it each time (hold the off button and the ice maker goes through a cycle). Water is getting into the tray, but little to no ice. According to the manual, the ice maker bin should be full in 48 hours. My friend said it may be the size of the ice cubes? Help please!
-Jamison
It sounds like the thermistor/thermostat in the ice maker has failed. Fill the ice maker by hand and see if it will harvest the ice cubes on it's own. If it doesn't, replace the ice maker. This is an update kit.
jbottomley7
Charleston, SC USA
Thanks for the reply Rick. I filled the ice maker by hand and it did produce ice in the tray (though the ice were stuck together because they were a bit larger). Thoughts?
