- FGHD2455LF1A
- Frigidaire
- 1-5 years
New member but have used this site before!
I hope you guys could possibly help me out
My Frigidaire FGHD2455LF1A isn't draining properly,
I have tried a few things.
I have removed drain hoses and they aren't clogged,
I have opened the drain pump and it isn't clogged and is in working order.
In the tube connected to the sump there was a small rubber piece that is floating around,
It looks like a check valve piece that has come loose and water flows through both ways,
It was in a half open position when I found it.
my dishwasher doesn't overflow when I run it once, it overflows if I run it a second time because of the left over water from the first full cycle.
Could this be a check valve problem?
If it so, where does the new check valve go? I can't see a place to hook a new one on.
Could the check valve be built into the tube that attaches into the sump on this model?
If it isn't a check valve problem, does anyone have any other suggestion?
Would be forever grateful.
This site has helped me before, it would be awesome if it could help me again!
Thank you,
Jordan
Thank you,
Jordan
