FGID2474QF7B Dishwasher is unresponsive. Looks like panel is locked/frozen.
FLHomeOwner
Central Florida
FGID2474QF7B
Frigidaire
Hi All!
I have a Frigidaire Gallery Dishwasher (FGID2474QF7B) that is unresponsive. It is stuck on the minutes displayed (like it's about to start) but nothing happens. I reset it via the breaker and no luck. I tried holding down a few buttons at the same time (suggestions I found online) with no luck.
Picture attached. Dishwasher is about 2.5 years old. Any Suggestions?
Open the door and hold down DELAY for 3 seconds.
If still nothing, then turn the breaker off overnight and turn it on in the morning and see if its back to normal.
If not, then you will possibly need one or both of these parts below.
Here's the user interface board for your model:
807022404 Board
Here's the control panel for your model:
117494801 Control Panel
pegasis
seattle
FPHD2491KF0 similar issue
I have similar issue on 6 year old Frigidaire dishwasher.
spent $800 on POS
3 second delay reset did not work
power shot off/reset gets only one setting (energy saver) to be used
all other setting don't work
if you try and set them, they don't work, or the timer keeps adding minutes
The main board was replaced 2 years ago to attempt to get this fixed, washer works but only one setting
I am thinking the interface board is bad
any thoughts?
Yes, your console keypad assembly has gone bad.
You will need to order a new console keypad assembly.
Here it is for your model FPHD2491KF0(Video Included):
Touchpad and Control Panel 5304475578
