FGIH3047VFB Frigidaire Induction Range only 50% of surface elements work
Jesse232
Pittsburgh PA
FGIH3047VFB
Frigidaire
I bought a Frigidaire Gallery 30'Front Control Induction Range with Air Fry, model number FGIH3047VFB 2 years ago.... Everything worked fine for two years until about a month ago when all my surface / cook top induction elements (4) started working at 50%. Meaning only half of each side is heating / working. I can see this because only half of a pan heats / cooks.
Is this a common or not so common issue?
I cant imagine that they all the elements went bad at the same time. There had been no electrical spikes or events that I can think of that would have caused this. I wanted to ask this question before I replace all 4 elements.
Any info on a fix would be appreciated
Yes, I agree, I doubt the elements are the problem, the generator boards control the elements.
I located another member that had a similar problem:
The difference between his problem and yours is just right side burners stopped working.
Here's the right side generator board for your model:
The generator board on the left side is the exact same part number as right side generator board.
Here's the video:
