TRB13
- FGIP2468UF0A
- Frigidaire
- 1-5 years
my dishwasher stopped working and displayed the ER code.
The door switch was also broken.
i've replaced the main circuit board and door switch..
When i put it all back together the display came back on normally.
When I tried to run a test load, I entered the cycle choice and closed the door.
Then a "close door" message scrolled on the display. When i opened the door again the machine started running with the door OPEN.
I thought I may have switched the black & white wires on the door switch so I opened it back up and switched them but the same thing happened.
Now after letting my frustration diminish a couple of days, I see the ER code appearing again.
Any ideas on what I should try next are very much appreciated.
Thank you to all that may send help my way.
