FGMV174KFB LED display numbers fading away
Utilaken
Utila bay islands honduras
FGMV174KFB
Frigidaire
Hello, I have noticed for the past 2 weeks that the LED display (clock) that the bottom 1/2 of the numbers are fading away, my question is can I replace what is needed without pulling the entire unit down, and could someone possibly help with with the correct part number needed ?? The model # is FGMV174KFB
. this unit is aprox 5 ish yrs old. Thank you in advance for any help in this matter
Ken.
Yes, just need to lower the consol part and leave the rest of the unit installed.....power off first!
Main-Control-Board-5304481625-01423066.jpg Printed circuit control board
This is NOT your model...but will give you an idea of the job...
[video=youtube_share;6SYUXvH56Ug]https://youtu.be/6SYUXvH56Ug[/video]
