FGMV175QFA Frigidaire Microwave Breaker Tripping
sb220
NJ
FGMV175QFA
Frigidaire
Hello All,
I have F-Gallery Series
Model # FGMV175QFA
When I open the door of the microwave when its on the breaker trips. I have the microwave on its on own breaker and still having issues. I called Frigidaire and stated its a safety feature.
Check the door interlock switches with a meter by opening and closing the door. The monitor switch, also known as a dead man switch, shorts L1 and N together to keep the microwave from working if the door is open. When the door is open power to the monitor switch is interrupted by the other microswitch.
