FIXED FGMV176NTW Frigidaire Microwave blows fuses...
divide_by_zero
Dayton, Ohio
I have received the two parts from Appliance Parts Pros. Before I let 'er rip, I have two questions. I read in another thread that the diode and capacitor or diode and magnetron could mutually cause the other to fail if one was bad.
1. Would it be prudent to go ahead and install the new diode?
2. Would it be okay to fire it up first with the magnetron unplugged to see that it doesn't (or does) blow the fuse?
It's not a safe idea. I have never had a reason to try that. If you do be sure to insulate the wire ends. There's over 2000 VDC and that's deadly voltage.
Luke Finley
Iowa
See if this helps. I've run into a lot of these where the switches check ok, but there's still an issue. This is the most updated service bulletin.
The diode might be OK, Keep in the package and don't open it unless you need it. If you don't open it you can return it.
You don't need to replace it
