[FIXED] 106.54589400 Kenmore Coldspot Ice Maker gear broken
Yoder
CA
My Icemaker stopped working a while back and I finally took the cover off to discover the plastic tines that hold the gear on broke, so the gear no longer turns. Where can I order the parts and how should I go about fixing? Model # on the ice maker is 106 626662, manufactured 8/18/04.
Thanks.
Yes, its your ice maker thats bad. You will need a new one.
You could purchase just the ice maker module, but its almost as high as a new ice maker assembly.
Here's the Ice Maker for your model you can order:
Manufacturer's Number: 4317943
Yoder
CA
Just to update this, I got my icemaker motor module and it is working perfectly. :)
Ok, sounds good.:)
Come back if you have anymore problems.
