FIXED: 362.7556191 Help replacing oven igniter
mcrump
TX
A week ago my gas oven stopped heating when baking. I did some investigating and my broiler works and stovetop so it must be the igniter on bottom. I have found out and removed the bottom but am stuck now and can't find the answer to go any further. A paper that was on back of oven said to remove the back burner and the igniter is attached to this. I only have the igniter that I purchased. Problem is the hex screws are under the back burner bar and I cannot reach them. Tried to remove the panel under the back burner but even taking out the heck screws and prying up on it I still could not pull it out. I cann't get to those hex nuts and the bar does not come up. Now I am not going to pull to hard on it not knowing if I should. I could feel the wires to the igniter go a ways back in there. The back of the oven has no entry and I pulled the drawer out but didn't see anything. I am stumped and cannot figure out how to go any further. Any help would be appreciated. I have attached some photos to maybe help. Again thank you for any help.
mcrump
TX
Okay figured out how to do it but don't know how to delete my post. Now I just need to figure out why the one wire is 1/2 inch to short of connecting. Ugh!!!
When you click the link to your bake igniter glow bar I'm posting below, you will see a video on how to replace it. If you follow the video, the wires should not be too short.
Here's the bake igniter glow bar for your model:
WB2X9154 Round Style Oven Igniter
mcrump
TX
thank you
Thank you for your reply Jake. I looked at the video but I did not access it from the back, Had to pull out the drawer and it was under there. I threaded those wires every which way to try to get it to stretch. Just finally cut and spliced the wires. Didn't want to do that but as a last resort I did. Going to watch it careful because of the gas but so far we have fire. :) Whew that job took all day but I always learn something. I bet my 58 year old self won't be able to move tomorrow after wallowing all over the floor. Haha!!
Yes, the difference in that video is that your electrical goes down below, not out the back.
I usually remove the whole flame shield to get better access to it. Its a little tricky on this model because the burner and flame shield are together.
Good job getting yours in.:)
