[FIXED] Coldspot(106.59592990) Ice Maker Making Noise
1der
Colorado
My ice maker is making strange noises. At times it is an intermittent clicking sound and then at times it makes a contstant humming sound. Any idea what this could be?
Did this just start happening?
If so, Its your ice maker thats going bad.
Here's the Complete Ice Maker for your model you can order:
Manufacturer's Number: 4317943
4317943
Jake<!-- / message --><!-- sig -->
1der
Colorado
Yes, this just started happening recently. The intermittent clicking sound almost sounds like the normal operation of the ice maker. The problem is that it continues on and on. Or if it does stop, it's making a constant humming sound.
Thanks for the ice maker link. I will order it now and then report back if it worked or not.
Ok, yes the new ice maker should fix it.:)
1der
Colorado
Hi Jake,
I installed the new unit about a 1/2 hour ago and I don't hear anything moving or any water coming from the fill tube. Does the ice maker need time to reach a certain temperature or do I have a problem? Thanks.
Yes, give it 12-24 hours.:)
1der
Colorado
I have an update. It took about an hour or two and then the ice maker starting working. Thanks for your help!
For anyone thinking that they need to replace the ice maker in their fridge, it really is a rather quick and painless operation. I'm so happy to have ice once again!
Excellent, good job.:)
