[FIXED] Dispenser not working
jafer
CHICAGO
I have a KSRG25FKSS04 Kitchenaide side by side Ref/Freezer. My ice dispenser just suddenly stopped working. The water dispenser works fine. The ice maker is making ice.
I openned up the front of the dispenser but really don't know what to look for.
As a side note, this started happening after my freezer suddenly defrosted. I followed one of your threads that indicated that the start relay/device was faulty. I took out and shook and it rattled. I am going to purchase the new part.
Do you think maybe when all the ice melted it might have fried the electrical board on the ice dispenser?
No, Not that I've ever seen before.
Yes, then that start relay on your compressor is bad.
Go ahead and replace it and give it 24 hours and then see if everything is working fine again.
Here's the start relay for your model:
Manufacturer part number 8201786 is RepairClinic item number 1177466
8201786
Let us know what happens.
Jake<!-- / message --><!-- sig --><!-- / message --><!-- sig -->
jafer
CHICAGO
Still doesn't dispense ice
Ice dispenser still doesn't work. Do you have other ideas/advice?
jafer
CHICAGO
Replaced Start relay
I forgot to mention that I did replace the start relay and ice dispenser still doesn't work. Other ideas?
jafer
CHICAGO
I openned up to replace motor and discovered that one of the wires was broken. Do you know which part and how to replace the wire or do I just try to solder back?:(
One of the wires on the electrical connector that snaps on the dispenser motor?
jafer
CHICAGO
yes. A red wire was loose from the white 6-wire connector when I was disconnecting the motor from the wires.
Can you put it back in place? Some had pin tabs you can bend out a bit so it says in secure.
jafer
CHICAGO
no, the wire just snapped off the pin tab. So I can't put it back. Do you know the part number for that wire harness?
Yes it is James.
jafer
CHICAGO
Wire harness
I finally got the wire harness but it seems different. There are only 4 cables connecting to the motor. Also, it does not have the female connector. It has male connector for the motor. Did I order the correct part #2206178 item number 826922?
Also, if this is correct part, can you point me to proper steps to dismantling old and replacing with new.
James
Hi James,
It shows to be the correct wire harness for your model. I've never had to replace this particular one before.
From the diagram it looks like you just pull it up from the top hinge, its #13 here:
jafer
CHICAGO
I finally got the correct wire harness for my freezer and after I replaced the wire harness, the ice dispenser was still not working. Luckly I still had the motor you suggested I replaced. I did so and it works like a champ.
Thank you SO much for your help!!!!!!!!!!!:3::3::3::3:
Excellent James, good job.:)
