Ronr533
HI Old School
I would like one of the extra seals you have. I sent you a message with my info
Thank you
Ron
Thank you
Ron
I just replaced the bearings, rear seal, front boot and the shell gasket. I had to buy 7 of the seals to make the minimum order (!), so I thought I'd see if anyone was interested in my spares. They are the rubber coated type with a double lip. 40X80X10mm. They are a bit different than the originals, but absolutely no one sells those as near as I can tell. I found this forum very helpful, and wanted to help someone else.
Hi, I just wanted to add a update for the Tub Kit available from Sears Canada and straighten a couple of things out that have been said over the last few pages.
- Tub Kit (part #26 970134453200) price as of Mar 25/2012 is $207.99 plus 10% shipping ($20.80) + applicable taxes
The $20.80 gets it sent to you by courier (5 day delivery)
- Re: Inner bearing seal (closest to tub)
Please,please do not install this seal with the lip/ spring pointing at the drum - this is wrong IMO and will cause the seal to leak/ and or fail prematurely.
The correct way is to have the lip/ spring pointing towards the inner bearing (or back of the machine if you will)
Please see the document by jnicosia titled - RearBearingV6.PDF (as seen of the first page of this thread) - picture on page 7
http://www.applianceblog.com/washers/RearBearingV6.pdf for further proof. Also even though the bearing is sealed - 2RS = "2 rubber seals" if you put
some grease between the bearing and the seal then the lip wil be riding on the grease but installed the other way - spring side towards drum then the
detergent will let the lip wear out on the shaft IMO.
There is a SKF seal guide book here http://www.skf.com/files/774717.pdf for anyone who wants to read up on everything you wanted to know about
seals but were afraid to ask.
- I will be getting the drum kit in the next week and will take pictures of my old one for comparison.
- Good luck to all on keeping this excellently designed but poorly manufactured running, by excellent design I mean the basic premise. If not for the aluminum
spider on the back of the drum it would go a long time without repairs IMO.
- I really wish someone would look at a class action lawsuit on both sides of the border because of the way this was setup to fail from the getgo
I just got my 417. apart today after reading all of these great posts for hours last night. I think I may be lucky! All seems well and came apart easy except for the inner bearing. I would really be interested in one of your seals. I plan to order bearings and other misc. today. I just signed up on this forum, so my PM isnt working. Thanks! mrd93465 at yahoo.comHi,
I had put mine back together months ago and was reading timetrippers thread on the seal. I am sure he is not tlaking about having the spring exposed to water but maybe im reading it wrong. Whenever I install a seal on any type of saft the spring faces inword to keep oil inside. Now in this applaction we are putting in reverse so the spring cant get exposed to water.
I am not an appliance expert, but the condition of your components is MUCH better than mine. I'd say you only need to do the bearings and seal (and maybe the belt and shocks) and you will be very happy with the result. Don't consider replacing the back of the tub unless it's leaking somewhere and even then you could patch it with some kind of epoxy. Mine had much deeper grooves worn in it than yours. Your spider shaft and bearing look great. You could even try it with the old shocks and see what happens before you replace them.
A quick update on my repair with one of the six spider bolts broken off. It is still running but it doesn't seem to wind out to the fourth highest speed anymore. It's not as quiet as the day I fixed it and ran it nearly empty ticks, rattles, etc. But my wife says it's fine and she loves it. So I'm waiting. I should be looking on craigslist for a broken one. I'd love to buy your spider if it weren't so far to ship.
I think the learning for me on appliance repair is that there's a big gap between the type of repair a professional has to do that restores full reliability for another year or two and rules out a callback, and the kind of take-your-chances repair that makes economic sense for a homeowner as an alternative to buying new right now. Mine has run for two or three months now, it's paid for the new bearings. So I'm ahead. My engineering student daughter helped and learned something so even my time was paid for in a way.
you install it spring side to the fluid to be sealed against. In this case soapy water.
Retention
When the seal’s basic function is to retain lubrication, pressure, or both, the lip of the seal (generally the spring side) must face toward the lubricant or the pressure being retained and generally be spring assisted (fig. 2g).
Exclusion
Most bearings fail from the entrance of foreign material and from the loss or degradation of lubricant. Dirt, abrasives, water and other liquids can interfere with the film of lubricant required to support the moving parts of a bearing in a sealed system. Reliable excluders generally include V-Rings and non-spring loaded seals.
Therefore, it’s vitally important for the seal to keep those materials from entering the bearing cavity. When the seal’s basic function is to exclude, the lip of the seal should face toward the contaminants instead of toward the bearing (fig. 2h). However in this case, only grease lubrication should be used since oil loss could be excessive.
