To install the inner bearing, I could not find anything closely matching the outer race diameter. So I disassembled the old inner bearing, and used its outer race to push on the new bearing's outer race to drive it home. Here is the outer race from the old bearing, the bearing initially seated, and the bearing fully installed:
I used that same old outer race to seat the seal, with the spring facing the bearings:
Here is the new drum next to the old drum:
I then installed the inner drum into the rear tub, assembled the tub halves with the new gasket, and reassembled the machine.
I am now on my fourth load of laundry, everything is nice and quiet, with no leaks.
Hope this helps others.
Leon
Leon
