FIXED: Humming noise on Frigidaire FGMV175QFA
deuce2003
Indiana
FGMV175QFA
Frigidaire
My microwave is making a humming noise when the door is closed. Exactly like the noise in the video below.
https://youtu.be/GbjvRZg8fMo
I tested the door switches with the door closed-
Top switch has continuity
Middle switch does not have continuity
Bottom switch has continuity
I believe the issue is with the control board but wanted to ask the experts.
Sounds like the control board: 5304506032 PC Board
Just to be sure, disconnect the two wires on the primary side of the HV transformer. That eliminates all the HV components and the high side of the microwave.
Tape the ends if necessary so they don't touch anything and see if the noise is still there.
