[FIXED] Kenmore Stovetop Burner TOO HOT! 790.95662100
rwenck
Columbia, MD
Good afternoon,
One of the large front burners on my glass-top Kenmore oven, Model # 790.95662100, always heats up too high. Even on low, it boils water and gets extremely hot. I cannot even use this burner because everything burns on it. What do I need to replace to fix this burner?
Thank you VERY MUCH for your suggestions!
-Ryan
Hi Ryan,
The problem is your burner switch, here's the one for your model you can order:
Manufacturer's Number: 316238200
Is it 54A the large dual front burner?
http://c.searspartsdirect.com/lis_png/PLDM/P0106105-00001.png
You just pull the knob#31 off, then take the back console panel#56 off, then you remove the wires and make were they go on a piece of paper, then remove the two mounting screws in the front from were you removed the knob, then install the new switch and your good to go.:)
Remember to unplug or turn the breaker off to your range first!
<!-- / message --><!-- sig -->
rwenck
Columbia, MD
Jake - Thank you so much! Your link was a better price than I had been able to find anywhere else. :)
Excellent Ryan.:)
