[FIXED] ksrs27ilbl13 not cooling
vin
frisco, tx
i posted a thread last year http://www.applianceblog.com/mainforums/showthread.php?t=10983. my issues died down a little, but are much worse out of the blue today.
it is only running for 5-10 seconds at a time 2-4 minutes apart. i turned it off for 2 hours...during this time i opened the freezer removed the back panel, used a hair dryer for any remaining ice on coils, used a siphon to empty the drip pan underneath as it was about to overflow. i then turned it back on and it's still running in that weird pattern.
temps are set to o*/35* according to my automotive laser thermometer i'm at 55*/52* after 2.5 hours.
any assistance would be greatly appreciated.
Was the evaporator coils clogged with frost again?
What is running 5-10 secs at a time 2-4 minutes apart? Your compressor in the back of the refrigerator?
vin
frisco, tx
by the time i got to it around noon today most of the ice had melted off, but there was a substantial amount of ice on the coils.
in regards to what's running...i'm not certain. the fan in the freezer runs constantly, but i guess it's the compressor. whatever part that usually kicks on but then turns off upon completing it's job.
just checked again...still doing the intermittent running and temps are 55*/55*.
Ok, then its possibly your start relay assembly that mounts on your compressor.
Here's the compressor start relay assembly for your model:
Manufacturer's Number: 2319792
Its #16 here:
Just unplug your refrigerator and take it off you compressor, and shake it, if it rattles, its bad, order a new one.:)
If it doesn't rattle then its likely you have a bad compressor.
Glad to help vin, good job fixing it.:)
