[FIXED] Sharp Carousel Inside light works about half the time
Algebrat
Eaton, OH
R530BW
Sharp
I think it is the bulb, but it could be a loose connection, since it seems to work intermittently. What is the best path to access the bulb? There isn't an easy access panel that I can see. It appears to be a night light bulb, but I suspect it is a special bulb.
Let me know your thoughts, thanks.
John
You will need to remove power, remove cabinet screws, pull towards the back and lift off the cabinet to access the light bulb.
Light bulb, 20 watt
Algebrat
Eaton, OH
Light Fixed, Thanks!
Hi, It turned out that it was just a loose bulb. With your guidance, I was able to fix it in about 15 minutes. I removed the tamper resistant screws in the back by cutting a slot with a dremel and then using a regular screw driver.
John
