FIXED: SMH1611W OTW Microwave night light
jben04
South Carolina
SMH1611W
Samsung
So our OTR Samsung microwave's night light wont shut off. or even cycle through the high,low setting,( the one under the microwave)
I had to replace the bulb because it was burnt out,and i noticed that the light wont turn off,,not too sure if its a loose wire, ( due to the fact we have just moved our house to our new property and maybe with the move it could've loosened somthing).
I was gonna try open it up but someone recommended me against this.
Could just keep the bulb screwed in etc,, but id like to see if i can fix it.
Any help would be appreciated,thanks :)
jben04
South Carolina
As far as i can recall,yes it was working before it burned out.With the new bulb as soon as its screwed in it comes on, but the "on, high,low" button has no effect. so to turn off the light u just unscrew the bulb. All the other functions on the microwave work no problem.
HOw easy is it to replace the part i need?
It's easy to replace. Just unplug the machine and remove the top grill then the screw that hold the control panel. Remove the board but leave all the wires connected and let it hang there. Install the new board the wires one at a time.
jben04
South Carolina
Now does the microwave need to be taken down or can the top grill be removed with it still mounted to the wall?
(sorry for more questions )
We welcome more questions. Ask as many as you want. The OTR microwaves are designed so most repairs can be done without taking it down. The door switches, TCOs, main fuse, and control panel can all be checked and replaced without taking it down. Sometimes it's easier to take it down if the problem can't be easily found.
