FIXED: WMH32519CS Open-Close Door Error
Beege
DFW
WMH32519CS
Getting door error message. Research seems to indicate door switches may be issue. Video to replace top and bottom latch electronic switches looks easy. Where is third switch? Also, could something else be the issue?
On your model there's an upper and lower switch holder. Each switch holder has room for 2 microswitches, one on each side of the holder. When checking the door switches always remove the common wire from the switch when checking for continuity. Check the switches by opening and closing the door and not by pressing the switch button.
Door Switch W10269460
Beege
DFW
Ordered all 3 switches (2 top and 1 bottom) as I didn't know which one was bad and didn't have meter to test removed switches. Broke tabs on both switch holders when removing switches.
Ordered the switches and holders from repairclinic.com for about $75 and installed. Unit now works.
Note: Repairclinic.com has detailed video on this repair which was a big help especially since my photos on my phone didn't take. Biggest headache was removing the wiring from the switches as tabs were on real tight. Took about 1.5 hours to disassemble and .5 hours to reassemble.
