FPHB2899LF4 Bottom Freezer Stopped Cooling
Chuckmartel
Regina
FPHB2899LF4
Frigidaire
Just notice earlier the temp was going up. Fridge temp is normal. Sounds like the compressor is running attempting to cool but can’t feel any airflow in the freezer itself.
Chuckmartel
Regina
*Update*
By the time I went to bed last night temp was at 21F. Woke up at 5 this morning, freezer was back down to 0, by 630 was back up to 7F and climbing.
Is the freezer fan motor running right now?
Chuckmartel
Regina
Fairly certain it was when I left for work this morning. I almost felt like something froze up since the temp was good earlier this morning then started rising again.
The Fan is not running in your last photo.
Chuckmartel
Regina
I had the fridge turned off. Had zero airflow before, melted off all the ice, reassembled and air flow is back, but I’m assuming I have an issue with my defrost system. The fridge was down for a few days in Dec with a MB fried so it’s iced up since then.
Well, if it was a defrost problem BOTH your refrigerator and freezer temps would keep rising and the freezer temp would not keep going back down, see what I mean? Your evaporator coil would be so clogged with frost you would not be able to see the coils at all period.:)
Put the evaporator cover back in place and keep monitoring it.
If you find the evaporator fan motor is not running when it should be running, Check for 12 volts DC to the fan between red and brown wires. Check for variant voltage (depending on high or low speed) between yellow and brown. If the volts checks ok then replace the Evaporator fan motor.
Here's the evaporator fan motor for your model you can order:
241509402 Motor
Watch this video to access/replace it: Frigidaire Refrigerator Replace Evaporator Fan Motor Video
Chuckmartel
Regina
Ah that makes sense. I’ll keep monitoring it. I did find the green wire that grounds at the tin cover fairly rusty, so cleaned that all up. Thanks for the responses and the help!!
Glad to help, keep us posted.
