FPHD2491KF0 lower door seal as part of liner assembly
DanKu
Toronto
FPHD2491KF0
Frigidaire
Our lower door seal inside the door of the dishwasher is in poor condition and we would like to replace it or at least remove and clean / fix. We contacted Frigidaire support and they indicated that the seal for the lower part of the door is only included as part of the liner assembly listed as part number 5304475579. There is no separate part for the lower door seal. Unfortunately, the liner assembly is $170.38, which is silly as we would only like to replace the lower door seal. Has anyone else tried to replace / fix the lower door seal on the liner assembly without replacing the entire liner assembly?
It only comes with the inner door panal....
frigidaire-liner-assembly-5304475579-ap4508532_02_m.jpg Liner Assembly
You would have to find a gasket the same length, same width, same depth, food grade, attach it to the door panal so it stays put when the door is opened and closed. I have not tried.
