FIXED FRA186MT2 Frigidaire A/C won't turn off!
stevon
San Diego
FRA186MT2
Frigidaire
I have a 4 year old Frigidaire FRA186MT2 which has been working great for years until a few weeks ago. The evaporator started to freeze solid with ice blocking air flow. Then I noticed that compressor does not cycle ever! thermostat setting or even the power button turned off makes no difference. A ghost has moved in and has taken control of my A/C! The only way to stop compressor is to manually unplug the unit! I guess a relay on the control board is welded contacts shut (on). Replace control board?
Hi Stephen,
Yes, you will need to order and replace the control board, and that will fix it.:)
5304476951 Pc Board
stevon
San Diego
Yesterday decided to try to fix the old A/C again, the new control board. Went to the rental house but I was not prepared, had no soldering iron, shrink tube and no wiring diagram. yesterday I had clipped a wire's insulation by mistake but had no way to fix it without a 30 mile trip. Today I arrived with everything needed or so I thought. The wiring diagram did not match what I was seeing. disgusted I went home and did some research. Armed with the correct diagram, drove back and rewired the original controller board, tested the plug and got 1300 ohms (no short) and plugged it in. It works! Not trusting the old board I put in the new controller board, removed the sludge in the bottom of the A/C pan, tested OK and now I'm in business, at least for a while anyways. Still going to look for a cheap replacement A/C deal though for the future, new and old board comparison below
Stephen
