Freezer frosting on the back side
Justtesting
GB2SHDXPS
It seems the freezer is not auto defrosting. Frost is forming on the back side of the bottom freezer. I don't know what to check.
The compressor and the fans are running constantly. Could this impact the compressor?
Please help!
GB2SHDXPS
Missing a few digits.
Where is my Model Number? | Appliance Aid
Inside the freezer on the back wall?
If yes, test the heater and stat first...
Defrost-Heater-Assembly-67001794-00770073.jpg Heater, defrost Manufacturer Number 67001794
[video=youtube;311BiD76iYg]http://www.youtube.com/watch?feature=player_embedded&v=311BiD76iYg[/video]
Defrost-Thermostat-12001937-00698954.jpg Defrost thermostat kit Manufacturer Number 12001937
[video=youtube;zmdsBkO46dk]http://www.youtube.com/watch?v=zmdsBkO46dk&feature=player_embedded[/video]
If they check ok, the control is then changed...if either test bad they get changed out first.
Main-Control-Board-12868513-00723728.jpg Electronic control (JAZZ) board with two LED digital displays and installation instructions Manufacturer Number 12868513
Justtesting
Thanks a lot for your help with this.
This is the number I found on the tag inside the fridge. There are no digits after. Maybe I should check somewhere else in the fridge?
I don't see the heater, defrost in the freezer. Should I take something out to see this part? Also, i cannot find the defrost thermostat.
View attachment 6664 Heater, defrost Manufacturer Number 67001794
View attachment 6665 Defrost thermostat kit Manufacturer Number 12001937
View attachment 6666 Electronic control (JAZZ) board with two LED digital displays and installation instructions Manufacturer Number 12868513
You took it off of the model/serial tag?
Both are in the freezer, behind the false back wall...attached to the evaporator/cooling coils.
