Freezer not staying cold fridge OK
Zeta30
Portland
PLHS69EESS2
Frigidaire
I started having an issue where the Freezer will not stay cold. It will get down to about 3 degrees for about 5 - 10 minutes then warm up to around 20 degrees. It constantly is doing this cycle.
I took the lower cover off the inside and found the upper part of the evap coils are caked with ice, the lower part is OK. (Photo attached).
From what I'm reading could this be a coolant issue? If so is it worth fixing on an 8 year old unit?
That definetly appears to be a refrigeration issue of some sort....leaker, restriction, inefficient compressor or any combination of these. BIG$ repair or new refrigerator time.
Zeta30
Portland
Thanks for the info Jeff, that's what I thought. I've had nothing but problems with that fridge so I don't want to even spend the money to have a technician come out to look at it.
