Fregidaire FRS26LF8CS1 water dispenser stops after a day of icemaker turned on. If icemaker turned off water restats after a day.
Rajago
Charleston,SC
FRS26LF8CS1
Frigidaire
My Frigidare water dispenser stops working a few hours after the icemaker is turned on. Restarts after a few hours if ice maker is turned off. The water inlet valve was just replaced about a month ago. Is the water line freezing somewhere? Or, could it be the valve?
That's very odd, I don't think the water line is freezing or you would not get water at all to the water dispenser.
You may have a diode issue, the diodes are located in the wire harness before the it connects to the water inlet valve.
Here's the diode kit:
Diode 5303918287
This post explains how to test it:
