Frigidaire Affinity BAQE7073KW0 no heat, no error code
JohnMMalone
Baton Rouge
BAQE7073KW0
Frigidaire
Dryer went out today. Unit was used and we have had for 3 years with no issues. Start a cycle and after a 10ish minutes the dryer stops, all lights on right side by cancel button blink and the small display is frozen where it normally has the 'spinning' characters. Checked voltage and am getting 240 as I had seen sometimes this could be an issue.
No heat and vent is not clogged or hindered. Wasn't sure if most likely heating element, or a control board? Which would be best to try first and what are the correct model numbers. The cycle stopping and display being semi frozen is more concerning than the no heat.
