pelagic2
- FAQG7011LW
- Frigidaire
- 6-10 years
Our Dryer spins and blows air - but doesn't heat. I read through other posts - but need a little guidance on what to do next.
Found the error as E5b - then it blinks 050 then Fld.
I see the solution as:
Position cycle selector to NORMAL, temperature selector to HIGH HEAT and touch START. Measure voltage across terminals on relay RL2 (heater relay) on electronic control. If meter reads 240V on electric models and 120V on gas models, replace electronic control. If meter reads zero, remove power from dryer. Disconnect wire going to NO terminal on the relay RL2. Reconnect power and measure voltage drop between terminal COM on relay RL2 and neutral. If meter reads zero, wire between incoming line and relay RL2 is open. If meter reads 120V, check the rest of the heater circuit.
But need a diagram to know relays, etc. Can someone walk me through? I tried calling a repairman, but no one in the area is taking any additional work?
