Frigidaire Dishwasher FPID2495QF - Water leaks i30 code
Gary Unis
Windsor, Ontario, Canada
FPID2495QF0A
Frigidaire
Water leaks into the bottom tray setting a i30 code, The water is dripping into what looks like a small funnel on the side of the unit down by the door hinge, I'm thinking either a door seal or it's overfilling, I timed the filling cycle between 3 and 4 minutes. Any ideas. Thanks
JimDavis
Pennsylvania
The same thing is happening to me, what did you do to fix it? replace the seal? I also read it could be a sensor that controls the amount of water in the unit. Any feedback or advice is appreciated.
Hi Jim,
i30 - aqua control ( just means you have leaked water into the base/bottom of the d/w )
You will need to order this part to fix it--->Pressure Sensor Part#5304504077
New part comes with special instructions for installing it.
