- GPDB998JC1
- Frigidaire
- More than 10 years
Twice now I have opened my dishwasher to find the bottom completely filled with water. The first time there didn't appear to be any leaking, but this time when I opened the door, water spilled out onto the floor. The first time, I took the inside assembly apart and cleaned out the best I could. I did not try and snake the drain tube out. I also took apart the drain under the sink and didn't find any obstruction. The sinks are draining fine, as well as our culligan system that is tied into the dishwasher drain. I can try and snake out the drain tube, or pull the dishwasher out and visually inspect it, but wanted to know if there was anything else I should check before I pull it out. I am hesitant to run the unit again, as we are in a condo building and am nervous about having water run into the unit below if it overfills again.
