Frigidaire dishwasher not pumping with enough force
btucker
Colorado springs
I have a frigidaire dishwasher and when it is running the water pressure is not sufficient to rotate the arms. the Arms are clean and free, the impeller is clean and it does move water, just not with the force it should. is this a motor problem or are motor problems run/no run?
The control has 3 settings, on SCOUR there is enough force to move the arms but in the other 2 settings there is weak pressure coming through the arms.
We would need the model number of your dishwasher first.
Click here: Appliance Parts
