- FGET3066UFA
- Frigidaire
- 1-5 years
My Frigidaire Double Wall Oven (FGET3066UFA) has started getting an F45 error anytime I pre-heat the upper or lower oven. After 1 to 5 retries it will usually work (seems like once I can get it heated a little everything is good).
The wiring diagram says F45 is an "Upper oven cooling fan speed too low" error and I should replace either the "cooling fan" or "oven control". The fan(s) are definitely noisier than first purchase so I suspect that's the cause.
I'm assuming cooling fan in this case is the 108 pancake fan in the upper oven diagram below?
The 108 squirrel cage fan in the lower oven diagram below would be ok? I'm assuming it's the F47 error "Lower oven cooling fan speed too low"?
