Frigidaire Dryer FER231AS0 Runs - No Heat
MMO
Vermont
It's the same wire. The thermostat is inline with the L1 side of the element. To measure voltage, one meter lead needs to go to + (L1) and the other lead needs to go to - (N). Since the thermostat is on the L1 side of power, both t-stat terminals are + (L1).
Gotcha. Regardless, based on the fact that I get heat when I short the wires together and bypass the high limit, that indicates that thermostat needs to be replaced, right? At this point that is our weak link.
