Frigidaire / Electrolux LEQ642DS0 squeaking
bes1208
Orlando, Florida
LEQ642DS0
Frigidaire
Heard this loud beeping, searched all over to find it only to discover it was our dyer squeaking while running a drying cycle.
I am assuming it's a bearing of some sort or maybe a belt? Any ideas?
[video=youtube_share;CYgwEjzkMKs]https://youtu.be/CYgwEjzkMKs[/video]
Hi Brian,
Yes, I hear it in the video.
Its usually the rear drum bearing that's the cause of that squeal noise.
Whenever you replace the bearing kit, its always best to replace the front glide felt pad kit as well.
Here's the rear bearing kit for your model you can order:
Drum Bearing 5303281153
Here's the front glide felt pad kit for your model you can order:
Felt Seal 5303937182
Also check your idler pulley to make sure the roller is spinning free both ways.
Here's the idler pulley for your model:
Idler Assembly 131863007
There is a HOW TO video in each part link, let us know how it goes.:)
Sounds good Brian, let us know how it goes.:)
