Frigidaire\Electrolux turntable does not work
Y2KGTP
Deltona, FL
plmv169dcd
Frigidaire
mfg august 06
Turntable does not work, does not seem to respond to turntable on\off in the control panel settings.
I am guessing a motor went bad here?
Power to the motor when it should be running but is not = new motor time. Cracked drive block would be another possible trouble maker.
If needed:
Turntable motor
Y2KGTP
Deltona, FL
Thanks for the reply, need to update my Email I did not get Email reply....
I assume I can check voltage possibly on the current unit?
Check for 120 volts AC across the two wires at the motor.
