sarat
- FG4H2772UF
- Frigidaire
- Less than 1 year
My 1 yr old FG4H2272UF Frigidaire refrigerator has a issue where it starts beeping with Hi T alarm for the Freezer. It shows anywhere between 21- 25 mostly and once at 64 F for 0 to -2 F set point. The temperature inside is high at 25-40 F. I can get it working again after playing with the set point up or down by 1 or 2 F and/or by cutting power for a short time. I have not been able to figure out what works but the Hi T alarm goes away after 3-4 tries in about 2-6 hrs.
When cooling, the T in freezer is as low as -10 F as measured by a dial temperature measurement device (must be based bimetallic strip principle) for 0 to -2 F set point. The Electrolux technician indicated that it is the controller board and Frigidaire has refunded our money for this discontinued model. Any thoughts on if this is really a controller board or can I fix it if it is the thermistor or something else. The problem started after about 7 months of installation.
