FIXED Frigidaire FGGF304DPFB double gas oven/stove top oven won't preheat
tonyc222
Farmerville, LA
FGGF304DPFB
Frigidaire
Top oven will broil, but will not preheat for the bake function. I replaced the igniter. The new igniter does the same thing as the old one. It comes on for the broil function, but not the preheat function. The broiler works so does that mean the valve is good? Is this a control board issue? Thanks in advance for the help.
Which ignitor??
There are 2 in the upper oven, 1 for the broil burner and one for the bake burner. What is the ignitor for the bake burner doing when bake is selected?
LINK > FGGF304DPFB Upper Oven Bake Ignitor
Not necessaily. That valve performs multiple functions. The portion for the broil function might be Ok but not for bake.
Whether that is a possibility will depend on the actual symptoms of the bake ignitor.
I don't usually recommend just replacing parts. Are you capable of any testing? 2 of the 3 possibilities can be ruled out with a continuity test.
Both the ignitor and oven gas valve can be tested for continuity to see if they're responsible. They would show no continuity (infinite resistance) to cause your symptom.
LINK > Appliance411 FAQ: How do I test for continuity?
If both those have continuity but the ignitor is not glowing at all, the electronic control would then be suspect.
tonyc222
Farmerville, LA
No continuity on the bottom igniter. Replaced it (not an easy job). All working now. The top igniter did have continuity. Should have tested before I replaced it. Thanks for your help. Merry Christmas and Happy New Year.
