A
AALEEM
Guest
- FGHD2433KF1
- Frigidaire
- 6-10 years
I have Frigidaire FGHD2433KF1 dishwasher at my rental property that was working fine till last week . Last week tenant told us that its not draining water. We inspected, found some debris and cleaned the junk and it started draining water again.
However, we realized that its spray arms were not rotating. We asked for someone's help who cleaned it further and after that lower arm started rotating again however upper arm(which is below the upper rack) was still not rotating and tenant says its not cleaning the dishes properly.
My question:
1). I checked the Tech manual and it says " The motor drives a pump which supplies 100 percent filtered water at a rate of approximately 12 GPM to one spray arm at a time. The spray arm’s operation is alternated by small “pauses” of the motor during the wash cycle." . Not sure how "alternated by small pauses" works e.g. lower arm rotates for 5 minutes and then upper arms rotates for next 5 minutes i.e. does anyone know upper and lower spray arm rotation cycle timing in FGHD2433KF1 ? - as its possible that when we check and conclude that the upper arm is not rotating ,it is actually not supposed to rotate and thus there is no problem with the rotation.
2). Otherwise , what could be the possible issue that upper spray arm is not rotating?
3). How to diagnose the problem and trouble shoot?
My question:
