David Eisan
- FGHG2368TF5
- Frigidaire
- 1-5 years
Hello,
Original Problem/Complaint, my Frigidaire fridge is no longer cooling, but the freezer is still freezing/working.
With the most common complaint being the condenser fan broken, I disassembled the bottom of the refrigerator, removed the fan and tested it with a 12v DC source. Not broken, fan works fine.
Evaporator however was very frozen up. Used a hair dryer to melt all the ice and snow off and put just enough of the fridge back together to test to see if it was going to work.
For first few days, everything was fine, Fridge cool, Freezer frozen.
Now evaporator looks to be freezing over again.
Is this because I didn't put the other front shield in place that covers the evaporator and the heater for it cannot work properly, or because of one of the following could be broken,
- 240356229 DEFROST HEATER
- 5303918776 THERMISTOR, FREEZER DEFROST, NTC, W/CONNECTORS
- 5304521781 THERMOSTAT,LIMITER/SAFETY
- some other problem
What would be a good next step?
Thank you,
David.
Thank you,
David.
